robertino Posted October 20, 2020 Share Posted October 20, 2020 Hi, I try to make truss data tags, something like autoplot truss tags, I want to have, not a total weight (truss + light devices), but a Total weight for light devices only, and a total weight for my truss.......I try everything........but nothing.......someone can help me? Quote Link to comment
JBenghiat Posted October 20, 2020 Share Posted October 20, 2020 Data tags will only show existing field information, not perform calculations. You can get the total hung weight for Hanging Positions because it is a data field that the object calculates. The only way to tally other weights is to have a script that writes to a custom field. Savvy Position Label will summarize the weight data for each type of attached object. https://benghiatlighting.com/software/products/pl It will also calculate the total attached weight for any Rigging Object, not just Hanging Positions. The weight for Truss pieces is a little unwieldy, as that value is stored in grams. Adding a feature to specifically summarize weights would definitely be possible, though. 1 Quote Link to comment
