SamIWas
Phantom old lines showing up randomly
I had imported a pdf, which I ungrouped to get normal lines.  It brought in hundreds of thousands of lines, which of course bogged down the machine.  I deleted all of it.  Weeks later, I'm working on the drawing, and periodically when zooming or performing a move command, these phantom lines reappear for a few seconds before going away.  Being that it's 100,000 of them, it causes a long pause on my MacBook Pro.  I have turned on every class and layer, and the lines are not actually in the drawing.  They are just phantoms showing up randomly.  Any idea how to get rid of these...it's absolutely draining my workflow speed.  I'm starting to think I will have to manually copy each and every existing thing to a new document...
4 answers to this question
How complicated is your drawing? You might try exporting back on version to a VW file and then updating that back to your current version.
Is there any specific action that causes the lines to show?
Have you tried to Purge unused objects?
I just opened this back up to say that I found the issue.  The lines were there, but were covered with a white rectangle, thus not appearing when I showed everything.  I was sure I had deleted them, but apparently I had not.
When you Ungroup a PDF you typically end up with 3 items. A bitmap of the PDF on top. A white rectangle (we think it represents the paper). And finally at the bottom a Group containing all of the vector linework and text that VW can extract from the file.
It sounds like you had ungrouped the PDF and deleted the bitmap but not the rest.
Glad you found the problem.
Yeah...I've done the deal with PDFs for many years, ungrouping then dealing with the resultant parts.  For some reason, I just missed that they were there since they were hidden and weren't selecting.
