jay_coke
Light illumination not Rendering, but does in Open GL
I made a space with lx fixtures in it. In open GL I can see the spotlight on the wall illuminating, but when I render in a renderworks style, custom, final quality, or otherwise, there is no illumination in the space. How can I fix this?
Edited by jay_coke
7 answers to this question
Could be many things, can you post the file or a sample?
The first place I would look are your texture, all Renderworks modes use the cast & receive shadow options set by the texture.
The lighting devices supplied by Vectorworks have the Default Instrument texture applied to the geometry with the cast shadows option unchecked to allow light to come out of the fixture.
Also look for objects in the path of the light that do not have a texture applied, I've seen them act differently in OpenGL and Renderworks when casting shadows.
Thank you for this! Unchecking "cast shadows" fixed the issue. However, I'm only getting soft shadows... I've tried turning off indirect light in the Renderworks style and turning the Soft Shadows option to low but neither are helping. Is there an option for that that I am missing?
Pink Clouds.vwx
Edited by jay_coke
There is a Soft Shadows option for each light source.
If you are using Spotlight run the Set Spotlight Rendering Options command and you can turn off soft shadows for all the Lighting Devices at once.
So Soft Shadows is unchecked... but if I need to Uncheck Cast Shadows to even get light to emit from the fixtures at all in renderings and Soft Shadows is a subgroup of that... then how can I get the shadows at all?
You can leave cast shadows/soft shadows on for the light but adjust the shadows option for the texture(s) applied to the objects.
Fair warning, soft shadows are very soft.
You need to use the settings on both the light and the texture to achieve the desired results.  This also means you need to apply a texture to an object, if there is no texture applied the object will be rendered with cast and receive shadows on.
All of my objects have an applied texture to them... I would honestly love hard shadows more than anything. As soon as I turn on "cast shadow" for the fixtures I loose all light emitting from the fixtures once I render. Here is a 2021 version
Pink Clouds v2021.vwx
@jay_coke It is what I originally suspected and probably the most common mistake people make when building symbols. The geometry in the lighting device symbol did not have a texture applied so the geometry of the lighting device was casting a complete shadow, not allowing the light to escape from the lighting device geometry. I edited the symbol and applied the default instrument texture to all the geometry in the symbol and then rendered.
