Travis.Designer
How to hide a wall temporarily?
Hi
How can I hide a wall temporarily?
When I try Visibility Tool, they only hide Class or Layer
Thank
Travis
Edited by Travis.Designer
^ This.
Basically just workarounds.
Or using the Clip Cube.
I think there are still traces of legacy objects hiding in VW
@Pat Stanfordknows how to access it.
But I would also love to have an option to temporarily hide
selected objects. I have that in Bricscad and got so used to
selective hiding.
Love me some Clip Cube, tho it can be a bit finicky to play with.
try holding down the back quote key to disable snapping
Try right click on wall and hide objects. It will appear again once you change a classes.image.thumb.png.ded7351da322a82d24257a0c70c3738e.png
44 minutes ago, Jonathan Pickup said:
i have an old tool that i made that hides objects, if you have my tools, it still works
Hi
Can you give more detail about this tool.
Thank
Thanks @Jonathan Pickup, I did finally figure that out. Finicky also in the sense that I need to orbit to odd angles/views to both select and move the relevant face.
I haven't experienced that,
once the Clip Cube is Selected and therefore activated,
I was able to approach the CC edges from different directions
to activate the CC Face I needed, including occluded Faces.
And temporarily deactivating snaps
(or moving cursor outside of geometries)
may help with correct Face reposition.
But I think you will get a feeling for it and I mostly just snap
to a suitable located object and just repeat if I was off.
