curtainwall material surface area does not work
Samuel Derenboim
Perhaps I utilized it the wrong way, but I am trying to compute surface area of a curtainwall for each of the components accurately. I created a wall Area schedule (default template) and did two types of walls - a regular wall, and a curtain wall. A regular wall accurately shows surface area of a material (connected or not...which is great for my purposes). Curtainwalls for some reason are notoriously elusive when it comes to computing surface area, and in this case showing area for glass for instance. I am using the =MATERIALSURFACEAREA('Glass Double Glazing Low-E Argon-filled MT') function, have assigned the material to all the components in the curtainwall, but alas, no cigar. Any help?
Also, something to note, material surface area computes only on one side of the wall as shown for the masonry! If you have alot of walls, getting the settings right can be tricky! Please note - the material surface area only computes wall surface area on the left pen line, not the right! so if you need to define orientation, that is the way to find out.
Thanks in advance!
1 answer to this question
