mattryan Posted October 15, 2020 Share Posted October 15, 2020 Hi All Is there a way to universally change all windows and doors to be on schedule instead of having to go through and individually click this box for each one? Thank you! Quote Link to comment
Pat Stanford Posted October 15, 2020 Share Posted October 15, 2020 Custom Modification under the Tools menu will let you change all your doors at the same time and all your windows at the same time. If you want to do both in a single step you will need to use a scripted solution. Quote Link to comment
mattryan Posted October 15, 2020 Author Share Posted October 15, 2020 Thank You Pat Quote Link to comment
Guest Wes Gardner Posted October 16, 2020 Share Posted October 16, 2020 @mattryan, you can also create a style with "On Schedule" set to "By Style" such that every time that window style is used, the "On Schedule" filed will be checked. I highly recommend the 'style' workflow for both doors and windows Wes Quote Link to comment
JMR Posted October 16, 2020 Share Posted October 16, 2020 A worksheet method: Create a door report with a column for "On Schedule", select the doors you want, and right-click and "Pick value from list" Quote Link to comment
