johncruet Posted March 31, 2006 Share Posted March 31, 2006 I noticed when meeting with another VectorWorks user who was demonstrating VW 12 that the command "Create Walls from Polygon," a great command in my current 10.5, is no longer available for Version 12. Is this true? This is a command I used quite frequently in my work, and its omission will inevitably adversely affect my decision to upgrade to 12. [ 03-31-2006, 01:24 PM: Message edited by: johncruet ] Quote Link to comment
Jonathan Pickup Posted March 31, 2006 Share Posted March 31, 2006 the Create Walls From Polygon command is still there in the basic workspace : Modify > Create Walls From Polygon The command is not in the Architect workspace, but you can add it yourself, I did... Quote Link to comment
G_Hannigan Posted March 31, 2006 Share Posted March 31, 2006 JC, It's still available. In the Standard & Classic Workspaces, it appears in the Model/Architectural menu by default. In the Architect Workspace, it can be loaded using the Workspace Editor. I am using VW 12 Arch, I assume that it is still in the Fundamentals version. George Quote Link to comment
G_Hannigan Posted March 31, 2006 Share Posted March 31, 2006 Jonathon, You're quicker than me! George Quote Link to comment
johncruet Posted March 31, 2006 Author Share Posted March 31, 2006 Thanks for the heads-up! Other than that, VW 12 looks very exciting, and, next big paycheck, I'm biting. Quote Link to comment
Guest Posted April 2, 2006 Share Posted April 2, 2006 In the Architect Workspace, go to Tool>Convert>Objects from Poly and select "Walls" as the object type. Quote Link to comment
Jonathan Pickup Posted April 2, 2006 Share Posted April 2, 2006 objects from polyline creates walls using the last wall style, you have to make sure that you choose the wall stlyeyou want beore you use that command. The walls from polygon gives you a little more control over the walls, allowing you to change the wall height, thickness and class assignment of the new wall. It?s easier to figure out the new wall position relative to the ploygon, so for most people it?s easier and faster to use. Quote Link to comment
Guest Posted April 4, 2006 Share Posted April 4, 2006 The objects from polyline does all of that for you too. You can determine whether the wall falls along the centerline, left or right of the polygon. However, the class is now controlled in the wall style definition as well as the wall height. Quote Link to comment
