hollister design Studio
Disappearing Viewports -
I've got a project that I've drawn the plan and the elevations in AutoCAD --- learning and working at the same time...
I've set up VW 'shuttle files' for both the plan and for the elevations.
On my main design file I have referenced viewports for each of the shuttle files on separate design layers (ExRwef, and ExRef-ELEV) and also on separate classes (V-XR ELEV, and V-XR PLAN) .
I've made an elevations sheet layer and placed viewports to the 4 elevation views from my shuttle file cad reference.
All looked good.
Then I went to a design layer to work a bit, then I went back to the elevations sheet layer...
3 of the 4 viewport had disappeared:
If I pan around they become visible while panning. If I zoom they become visible while zooming.
If I select them their outline becomes visible and selected:
If I export to PDF they print as visible:
But I can't see them.
I take that back -  as I was writing this 2 more became visible... for no apparent reason.
Frustrating!
I have a decent older professional graphics card (AMD Firepro v5900) and have no problems in any other 3D, drafting, or design programs.
Ant thoughts?
5 answers to this question
If you restart your computer does it behave?  Other people will understand this way better than me, but I think that could be a graphics card or graphics memory issue.  You might want to give tech support a call.
Does it correct the problem if you change the Navigation Graphics to something other than "Best Performance" (in the Display pane of the Vectorworks Preferences)?
I thought it might be my graphics card, as it was an older AMD FirePro V5900.
I've updated to a current model, AMD Radion Pro WX 3200 and am still occasionally experiencing this issue.
I know in AutoCAD there was a set limit to the number of view ports you could allow to refresh per sheet.
This was an adjustable number that was user controlled.
