hollister design Studio 74 Posted October 9, 2020 Getting my first schedule together in VW and I'm looking for a way to have a column that has screen input cells. I've made a schedule and have it populating and sorting well: I would like to add the size data as I go. How do I make the "SIZE" column so I can enter data manually? Thanks! Quote Share this post Link to post
bgoff 174 Posted October 9, 2020 This will adjust the instance or symbol info per that document. Quote Share this post Link to post
Pat Stanford 1,638 Posted October 9, 2020 Vectorworks has what were originally called "2-way worksheets". Any cell in a database that displays Record.Field information can be edited in the worksheet and the data will be stored in the Record. If you change the data in the Record in the Object Info Palette, the next time the worksheet recalculates the data in the worksheet will be updated with the most current information from the record. You are not able to enter any data in a database cell unless that cell contains Record.Field data. So if you just want to add a note, you will have to add another Record.Field or repurpose a different field. HTH Quote Share this post Link to post
