Link label defaults when device is moved
Hi Andrew,
As of Vectorworks 2021 the Link object is deprecated. ConnectCAD is now fully compatible with Vectorworks Project Sharing and this is now the recommended way for multiple users to work together on the same file. You find lots of info on Project Sharing in the Vectorworks Help.
In 2022 the Link mode of the Connect tool will also be removed. Links though ingenious proved to be almost impossible to maintain properly and in essence duplicated the functionality of Project Sharing. So for that reason it was decided to relegate them to Legacy status.
Using Project Sharing the best way is to divide your project by layers and allow each designer to check out and work on separate layers. The Connect tool in arrow mode lets you connect between layers.
Hope that clarifies things.
Best regards
Conrad
