Travis.Designer
Interiorcad - how to add custom Hinge 3D?
9 minutes ago, Stephan Moenninghoff said:
Afk right now. Will explain in a bit.
Hi Stephan
I try to add hinge to this cabinet:
However, I can not find this kind of hinge in the list
Thank
As for the file format: you can simply choose "Vectorworks interiorcad" from the list and then copy and paste into your document. This is a Java applet and is slightly temperamental so if it does not work as expected, just choose STEP and download. Then, drag and drop into your document. I will make a short film to explain how to proceed with the hinge from there on. (As soon as I get a chance).
Posted (edited)
Hi Stephan
I did  as your instruction.
They will import new hinge to project. however I can not find it in the list therefore I can not automatic place 2 hinges.
Are there other solution?
Edited by Travis.Designer
