flickering screen after publishing
stevewrightni
Hi,
I have a number of sheet views set up as hidden line (elevations, plans etc) and a view sheets set up as open GL ISO views (total around 10 pages)
When Vectorworks completes publishing to pdf, I have found if the last page was the open GL page, it suddenly flickers rapidly and does not let me change view, sheet view or layers - I have to restart. It does however let me save
Is this a bug? (I use other programs so I doubt its graphics card)
4 answers to this question
Can you please try it again and see if it is repeatable. If it is repeatable,  please send the file, the steps to reproduce, and as much detail about your system setup as possible to Tech Support so they can try to replicate the problem.
It could be a bug, but it is not an issue I have heard of before, so it is likely an edge case or a one time glitch.
Hi,
Following another publish of my document I have been faced with a vieport like this that does not change when i press update in OIP
Also, when i go into the viewport itself, the screen goes black!
My system spec:
Intel I7 2700K @ 3.5GHZ
32gb Ram
Windows 10 Pro
Graphics:
Nvidia GTX 1060 6gb
Vectorworks 2021
