P Bartoli Posted March 24, 2006 Share Posted March 24, 2006 I dont' know if it's possible, but I'd like to use the same hatch pattern rotated as the object it is being applied. I try to explain: I'm drawing a plan, with some rectangular grids (rectangles with a grid pattern). These are of different shape, dimensions and rotation. Usually when you apply the same hatch to different objects, not matter what, the hatch doesn't change rotation: that's what is supposed to do! Can I have two objects using the hatch pattern, to have with different rotations? Else is it possible to "break down" the hatch and transform it into lines, so it's possibile to rotate it with the object containig the pattern? Thanks Quote Link to comment
mike m oz Posted March 24, 2006 Share Posted March 24, 2006 You can apply a hatch manually. It will create a grouped set of static lines (ie. not associative). Select your object and go to: - VW 11 and earlier Tool / Hatch - VW 12 Modify / Hatch You will be able to nominate the start point for the hatch and the angle of the hatch. Quote Link to comment
Ray Libby Posted March 24, 2006 Share Posted March 24, 2006 There is a rotate hatch tool at www.vectordepot.com under Plug-Ins. It's a fairly complicated procedure. Quote Link to comment
Travis Posted March 24, 2006 Share Posted March 24, 2006 Paolo, Since symbols have their own origin, you just need to make symbols of your objects. Like this: 1) Draw the object with appropriate hatch, 2) rotate the object, if necessary, to align properly with hatch, 3) select all components of the object and Make Symbol, leave original in place, if appropriate. Now, rotate the symbol as needed for main drawing. . .hatch will rotate with the symbol. Good luck, Quote Link to comment
