Slicing command
Hi @josue Corona ,
   There is not a single command that will do that. There are commands in the VS language that will return intersection points between objects:
LineCircleIntersect()
LineEllipseIntersect()
LineLineIntersection()
EllipseEllipseIntersect()
   And there are other commands that will determine if the points in question are on Line segments, or Arc segments:
PtOnArc()
PtOnLine()
   But to use these the way you are probably hoping for will require a fair amount of coding to take the points they return and manipulate your target object to break at the right spots. If you like Analytic Geometry you can get there from here. If not, you might consider hiring someone who does.
Not sure if this helps,
Raymond
