mees
import new fixtures
where and how can i import fixtures in the vwx libary which are not there yet. i try to find the PROLIGHTS PIXIEBEAM LED Moving Beam and import it in the vwx libary so i can use them in my drawing.
thanks in regards
1 answer to this question
The Prolights PIXIEBEAM  is already in the Spotlight libraries,
In the resource manager look in
Vectorworks Libraries>Objects -ENT Lighting Instruments>Prolights
or
use the search field at the top of the resource manager
To answer your question about getting new fixtures there are several options
you can create yourself, there are youtube tutorial videos that help explain the process.
If you are a service select member you can make a fixture request through the service select portal and our content team will make it for you.
If it is available as a GDTF it can be directly imported (you can also create your own GDTF using the GDTF fixture builder)
