Custom Selection for Lighting Fixtures
The Custom Selection command is in the Tools menu. If you can't find it then you will need to add it to your workspace using the Workspace editor.
You should be able to make scripts for selection of specific Lighting Devices based on Field Values or better still, download Joshua Benghiat's excellent Savvy Selection tool which is a must-have.
https://www.benghiatlighting.com/software/products/ssi1
Ah, I see. Nice to know that people do their own plugins. Nice one!
Thanks!
Hi Martin,
I'll put in a plug for AutoPlot Tools for Spotlight. http://autoplotvw.com/
It's a set of really useful commands & tools that I use every day. There are commands to select lights by Position/Type/Channel/Dimmer/Legend/Symbol & Class.
684688124_Screenshot2020-10-09at10_43_45.thumb.png.cc856a998d8ea65923164adf7dfa2fc0.png
But the one I use the most is 'Select by Field Value'.  This opens a dialogue window with loads of configuration options.
 1195570100_Screenshot2020-10-09at10_43_58.thumb.png.11c3a3aa88dee8b09697a80875f88c9d.png
Hope that helps!
1 hour ago, Cookie_NZ said:
Hi Martin,
Hope that helps!
Cheers!!
