Worksheet on Drawing is a blank square
A.D.K.
Hello,
When I try to put a worksheet on a drawing, it shows up and prints only as pictured, not as the worksheet.  What am I doing wrong?
I am inserting it by clicking "worksheet on drawing" from the worksheet's file menu.
I have restarted vw several times since noticing the problem.
It occurs in several files, including a fresh blank one.
Thanks!
5 answers to this question
On 10/2/2020 at 12:11 AM, A.D.K. said:
Pro tip: it shows up as a placeholder in the pdf if you print with the worksheet open.  D'oh.
Probably I made it and now I just can see a square like you without any data.
I deleted and added the worksheet to the drawing again, but I just can see an empty rectangle.
😕 this is a bug?
