GetSpaceNumForObj
Hi,
I've been looking around for answers, but without the result I'm looking for...
I try to create a worksheet that lists all the instances of a particular symbol and in which space it is placed. The closest I got was via:
formula: =DATABASE(((S='74 WC 01') & (Sto='first')))
then 2 columns with: =s / =GetSpaceNumForObj
I seems that the GetSpaceNumForObj looks for all the space objects below because it's also listing the space numbers of ground floor spaces. When I change 'first' into 'ground floor' it only lists the space numbers on the ground floor...
when I add criteria to GetSpaceNumForObj (ea: (Sto='first')) it will prompt only true or false and no numbers....
Anyone any Idea how to fix this?
Thanks in advance!
Nico
Edited by nicovanderschaaf
  • 2 weeks later...
The way you made the worksheet now is the same way I would have done it, I foresee no problems.
I can only find one thing that could have been the issue with the first file
Did you update your Vectorworks between making the first and the second file?
because in SP4 they fixed an bug with GetSpaceNumForObj.
Quote
VB-168111 GetSpaceNumForObj not working when space has no height
