BGD Posted October 1, 2020 Share Posted October 1, 2020 Hi, 2 questions w.r.t a side view elevation 1. How can I can rid of the ground line.. it is probably coming due to side view of design layer. I have no lines drawn there. 2. On left hand side, the rose shrub is showing to be going through the house wall. Is there any way to fix it? Thanks for taking time to help. Quote Link to comment
CipesDesign Posted October 2, 2020 Share Posted October 2, 2020 Question 1) You could use a Crop that just barely covers the line. Ideally I would want to know what that line is and put it in and invisible class. It could be a Section Line? Note: FWIW I was alway taught that ground/grade lines are desirable in elevations... Question 2) Unfortunately Image Props are not real plants (LOL). You could try a couple things: Move it; make it invisible for that view; make narrower by scaling just the width, or you could maybe even draw over it in annotations with a polygon filled with the brick image... 1 Quote Link to comment
BGD Posted October 2, 2020 Author Share Posted October 2, 2020 @CipesDesign 1. I might have to use the crop as I really dont know what that line. Looks like its picking crop rectangle's bottom line for some reason. Other lines of crop's rectangle is not showing. Thanks for helping. Quote Link to comment
