C. Andrew Dunning Posted September 30, 2020 Share Posted September 30, 2020 Posting this in multiple places as I'm getting repeated inquiries regarding this... Many users are having issues with certain bumper and speaker Symbols when used with our Audio ToolSet 2 tools and the stock Vectorworks® audio tools - mainly, when building arrays. They're seeing things like arrays with HUGE spacing in-between elements, guide-lines being WAY longer than the bumpers and speakers of which they are part, and Symbols in the Array Config dialog preview boxes displaying at a fraction of the desired size. (Sound familiar??) The problem is that in very early versions of the "__ATS-BumpModData" and "__ATS-SpkrModData" records the different dimension fields ("Front Width," "Depth," "Thick," etc.) were defined as "Number" fields defined as Dimensions. This was all well-and-good as long as "Imperial" Symbols were never used in "Metric" models and vice-versa. When this happened, Vectorworks® got confused and did things like thinking 520mm is 520'. This was fixed several years ago but some of the content in Vectorworks'® catalog has not been updated, yet. So...if you're seeing this sort of thing...while the file containing the Symbols you wish to use is open...: 1) In the Resource Manager, right-click on either the "__ATS-BumpModData" record or the "__ATS-SpkrModData" record and select "Edit..." In the dialog that opens, all of the entries in the "Type" column should be "Text." One-by-one, select the entries that are not and click the "Edit..." button. In the "Type" Pop-Up, select "Text." Click "OK," fix the next one, and so-on. When finished, click "OK" to close the "Edit Record Format" dialog. 2) Still in the Resource Manager, right-click on the problem-child Symbol and choose either "Edit 2D Components" or "Edit 3D Component." With NOTHING selected (click in open space), click on the "Data" tab of the Object Information Palette. Either "__ATS-BumpModData" or "__ATS-SpkrModData" will be in the "Record Format" window. Select the given record and check and/or correct the dimension values that will be in the lower part of the OIP. MAKE SURE EACH VALUE INCLUDES THE APPROPRIATE UNIT MARKER (',",mm,m, etc.). As mentioned above, you might find things like 520' that should be 520mm. When all is correct, click the "Exit Symbol" button in the drawing space. Save your file. All should be good - though you might have to click the OIP "Update" button for the different object instances in order for the changes to take effect. I hope this helps some of you... 2 Quote Link to comment
JBanks22 Posted November 5, 2021 Share Posted November 5, 2021 This is what I've been tracking down for a few days. Should've just started with Landru tips! Thanks, Sir! 1 Quote Link to comment
C. Andrew Dunning Posted November 5, 2021 Author Share Posted November 5, 2021 100% my pleasure! Quote Link to comment
Mark Aceto Posted November 5, 2021 Share Posted November 5, 2021 On 9/30/2020 at 2:29 PM, C. Andrew Dunning said: Posting this in multiple places as I'm getting repeated inquiries regarding this... Many users are having issues with certain bumper and speaker Symbols when used with our Audio ToolSet 2 tools and the stock Vectorworks® audio tools - mainly, when building arrays. They're seeing things like arrays with HUGE spacing in-between elements, guide-lines being WAY longer than the bumpers and speakers of which they are part, and Symbols in the Array Config dialog preview boxes displaying at a fraction of the desired size. (Sound familiar??) The problem is that in very early versions of the "__ATS-BumpModData" and "__ATS-SpkrModData" records the different dimension fields ("Front Width," "Depth," "Thick," etc.) were defined as "Number" fields defined as Dimensions. This was all well-and-good as long as "Imperial" Symbols were never used in "Metric" models and vice-versa. When this happened, Vectorworks® got confused and did things like thinking 520mm is 520'. This was fixed several years ago but some of the content in Vectorworks'® catalog has not been updated, yet. So...if you're seeing this sort of thing...while the file containing the Symbols you wish to use is open...: 1) In the Resource Manager, right-click on either the "__ATS-BumpModData" record or the "__ATS-SpkrModData" record and select "Edit..." In the dialog that opens, all of the entries in the "Type" column should be "Text." One-by-one, select the entries that are not and click the "Edit..." button. In the "Type" Pop-Up, select "Text." Click "OK," fix the next one, and so-on. When finished, click "OK" to close the "Edit Record Format" dialog. 2) Still in the Resource Manager, right-click on the problem-child Symbol and choose either "Edit 2D Components" or "Edit 3D Component." With NOTHING selected (click in open space), click on the "Data" tab of the Object Information Palette. Either "__ATS-BumpModData" or "__ATS-SpkrModData" will be in the "Record Format" window. Select the given record and check and/or correct the dimension values that will be in the lower part of the OIP. MAKE SURE EACH VALUE INCLUDES THE APPROPRIATE UNIT MARKER (',",mm,m, etc.). As mentioned above, you might find things like 520' that should be 520mm. When all is correct, click the "Exit Symbol" button in the drawing space. Save your file. All should be good - though you might have to click the OIP "Update" button for the different object instances in order for the changes to take effect. I hope this helps some of you... Is there a way to pin this post at the top of the forums, so it won't get buried? 2 Quote Link to comment
