Change Default Scale for New Drawings
Set the scale and then save the file as a Template. You can also store any resources that you nearly always use as part of the template.
If you really want to have the template with your preferred scale open when you select new (instead of having to select the template), you can save the template with a name of default.sta in Applications:Vectorworks XXXX:Libraries:Defaults:Templates.  Replace the XXX with the name of your application folder.
Curious when and why this changed.  I seem to recall in versions going back to 2015 and prior that you could just change the default scale for new documents in the Vectorworks Preferences.  This seems really problematic to have to go around and back with a default template just to do something simple like change the scale that is applied when you create a new document.  Why 1/4"?
