BGD 4 Posted September 29, 2020 Hi, I have created elevation viewport of 4 garden walls (North, East, West, South) on separate sheet layers. Now lets say I am making any changes to the design layer (like adding plants or changing the hardscape a bit, the same changes are not showing on elevation viewports even after updating. Why is this happening. Does that mean I have to make same changes in design layer of all the viewports separately? Thanks Quote Share this post Link to post
fabrica 97 Posted September 29, 2020 check your changes are on classes that are on in each viewport.. 1 Quote Share this post Link to post
bgoff 142 Posted September 29, 2020 If you made changes and added Classes or Layers after you created the VP then by default the new Classes or Layers are off for that VP. 1 Quote Share this post Link to post
Pat Stanford 1,425 Posted September 29, 2020 When you create a new Class there is an option in the Class dialog box where you can choose if the class will be Visible/Invisible/Grey in existing viewports. If you Duplicate a class you won't get the dialog box and it will use the same setting as what you used the last time you where in the Class dialog box. 1 Quote Share this post Link to post
BGD 4 Posted September 30, 2020 @fabrica @Pat Stanford @bgoff All helpful and to the point replies. Thanks Quote Share this post Link to post
