kcarter Posted March 17, 2006 Share Posted March 17, 2006 When I save to PDF half of my drawing gets cut off. I have the Page Setup & print set exactly the same, printing at 100%. I used the save as button & did used the save as "PDF" under output option in the print dialog box. This only happens every now & then. most of the time it saves fine. Help!! Quote Link to comment
alanmac Posted March 17, 2006 Share Posted March 17, 2006 Check the set up of any printer you have itself. If you have more than one printer on your system it may be changing and you have not noticed. But as I said, just check your printers page size and orientation just before you decide to check the "pdf" option. Alan Quote Link to comment
Kevin Posted March 17, 2006 Share Posted March 17, 2006 Are you sure that you are getting one page with half the image and not two or more pages with each page containing parts of the image? Quote Link to comment
