matteoluigi Posted September 28, 2020 Share Posted September 28, 2020 thanks for your great help. Where can I find instructions how to use an if-clause in vectorscript? Quote Link to comment
matteoluigi Posted September 28, 2020 Author Share Posted September 28, 2020 Quote IF COUNT((R IN ['Wohnung']) & ('Wohnung'.'Whg-Nr'=NR) & ('Wohnung'.'Zimmertyp'='Wohnen') | ('Wohnung'.'Zimmertyp'='Zimmer') | (('Wohnung'.'Zimmertyp'='Arbeitszimmer'))=1) THEN EINZW := EINZW+1; IF COUNT((R IN ['Wohnung']) & ('Wohnung'.'Whg-Nr'=NR) & ('Wohnung'.'Zimmertyp'='Wohnen') | ('Wohnung'.'Zimmertyp'='Zimmer') | (('Wohnung'.'Zimmertyp'='Arbeitszimmer'))=1) THEN ZWEIZW := ZWEIZW+1; IF COUNT((R IN ['Wohnung']) & ('Wohnung'.'Whg-Nr'=NR) & ('Wohnung'.'Zimmertyp'='Wohnen') | ('Wohnung'.'Zimmertyp'='Zimmer') | (('Wohnung'.'Zimmertyp'='Arbeitszimmer'))=1) THEN DREIZW := DREIZW+1; IF COUNT((R IN ['Wohnung']) & ('Wohnung'.'Whg-Nr'=NR) & ('Wohnung'.'Zimmertyp'='Wohnen') | ('Wohnung'.'Zimmertyp'='Zimmer') | (('Wohnung'.'Zimmertyp'='Arbeitszimmer'))=1) THEN VIERZW := VIERZW+1; IF COUNT((R IN ['Wohnung']) & ('Wohnung'.'Whg-Nr'=NR) & ('Wohnung'.'Zimmertyp'='Wohnen') | ('Wohnung'.'Zimmertyp'='Zimmer') | (('Wohnung'.'Zimmertyp'='Arbeitszimmer'))=1) THEN FUENFZW := FUENFZW+1 however doesn't work Quote Link to comment
Pat Stanford Posted September 28, 2020 Share Posted September 28, 2020 Instead of trying to get 6 to work at once, get one working to get the format then expand. The basic format is IF(some condition) THEN Do Something Else Do Different Thing; I often include Begin and End inside an If function even if I only have a single line of code in the thing I want to do so that if I need to add more code later the structure is already there. IF(Some Condition) Then Begin Do Something; End ELSE Being Do a Different Thing; End; Note that there is no semicolon after the end before the ELSE. If you are using a single line you must not have a semicolon before the ELSE either. IF COUNT((R IN ['Wohnung']) & ('Wohnung'.'Whg-Nr'=NR) & ('Wohnung'.'Zimmertyp'='Wohnen') | ('Wohnung'.'Zimmertyp'='Zimmer') | (('Wohnung'.'Zimmertyp'='Arbeitszimmer'))=1) THEN EINZW := EINZW+1; So this looks to be fine syntax as long as you don't need an Else. Are you sure that your conditions are being met? Try simplifying it and see if you can get EINZW to increment. Maybe just count the objects that have a Zimmertyp='Zimmer' The source for general syntax for Vectorscript is the Vectorscript Language Guide. It can be downloaded from this page of the Developer web site. https://developer.vectorworks.net/index.php/VectorScript 1 Quote Link to comment
matteoluigi Posted September 28, 2020 Author Share Posted September 28, 2020 @Pat Stanford does there also exist sth like else if? Quote Link to comment
MullinRJ Posted September 28, 2020 Share Posted September 28, 2020 @matteoluigi , There is a problem with your syntax of the 6 IF statements. Where you have " ))=1) " you should have " ))) =1 " Your last parenthesis should be to the left of the "=". The syntax is essentially " COUNT ( ... ) = aNumber ". 28 minutes ago, matteoluigi said: does there also exist sth like else if? Yes you can have statements lilke: if ( ) then begin end else if ( ) begin end else if ( ) begin end else begin end; Notice there is only 1 semicolon at the end, and not after each else if clause. HTH, Raymond Quote Link to comment
Pat Stanford Posted September 28, 2020 Share Posted September 28, 2020 @MullinRJ is correct as usual. The caveat I would make is that it is not an ELSE IF. It is an ELSE that uses and IF as the if condition. Subtle difference but important. There are languages which specifically have ELSEIF syntax. Vectorscript (and Pascal on which it is based) don't. Nested IFs can be very useful, but also very complicated to debug. Be careful with your parentheses, Begin/End statements, and indentation. I always use double indentation, one set for the nesting of a Begin/End pair and then the code inside the begin/end is indented again. That makes it easier for me to read the code. 1 Quote Link to comment
matteoluigi Posted October 1, 2020 Author Share Posted October 1, 2020 yeah, thanks, I got it all running, now 🙂 Now I would like, to write my results in a worksheet. Still working on it (and maybe thinking about running the script within a worksheet) {In this script, I count a) how many objects are connected with the database "Wohnungsnummer" (number of flat/apartment) b) in a for to loop i do loop through all apartments (in fact the loop runs as often as many rooms are in the building, not as many apartments, but, that's not my main priority) - every loop the script counts the number of rooms which are living rooms, rooms or workrooms (it's the way you define flats in germany, a 3 room flat for example consists of a kitchen, a bathroom, a corridor, a living room and two sleeping rooms, you only count the living room and both sleeping rooms)} PROCEDURE zaehlen; VAR NR: INTEGER; {counter for the running loop} ANZAHL: INTEGER; {number of all rooms} ZANZAHL: INTEGER; {number of rooms of the actually checked apartment} EINZW: INTEGER; {number of all 1 room-appartments} ZWEIZW: INTEGER; {number of all 2 room-appartments} DREIZW: INTEGER; {number of all 3 room-appartments} VIERZW: INTEGER; {number of all 4 room-appartments} FUENFZW: INTEGER; {number of all 5 room-appartments} BEGIN ANZAHL := COUNT(((('Wohnung'.'Zimmertyp'='Zimmer')|('Wohnung'.'Zimmertyp'='Wohnen')|('Wohnung'.'Zimmertyp'='Arbeitszimmer')))); {EINZW :=0; ZWEIZW :=0; DREIZW :=0; VIERZW :=0; FUENFZW :=0;} FOR NR:=1 TO ANZAHL DO BEGIN {Schleife, die alle Wohnungen "durchläuft" } ZANZAHL := COUNT(((('Wohnung'.'Whg-Nr'=NR) & (('Wohnung'.'Zimmertyp'='Zimmer') | ('Wohnung'.'Zimmertyp'='Arbeitszimmer') | ('Wohnung'.'Zimmertyp'='Wohnen'))))); {Zählt, wieviele Zimmerin der Wohnung sind mit der Wohnungsnummer NR.} IF (ZAnzahl=1) {erhöht den Einzimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN EINZW := EINZW+1; END; IF (ZAnzahl=2) {erhöht den Zweizimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN ZWEIZW := ZWEIZW+1; END; IF (ZAnzahl=3) {erhöht den Dreizimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN DREIZW := DREIZW+1; END; IF (ZAnzahl=4) {erhöht den Vierzimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN VIERZW := VIERZW+1; END; IF (ZAnzahl=5) {erhöht den Fünfzimmerwohnungs-Zähler um 1, wenn die Whg ein Zimmer hat.} THEN BEGIN FUENFZW := FUENFZW+1; END; END; CreateText(Concat('Da sind ', EINZW, ' Einzimmerwohnungen, ', ZWEIZW, ' Zweizimmerwohnungen, ', DREIZW, ' Dreizimmerwohnungen ', VIERZW, ' Vierzimmerwohnungen und ', FUENFZW, ' Fünfzimmerwohnungen.')); AlrtDialog(Concat('Da sind ', EINZW, ' Einzimmerwohnungen, ', ZWEIZW, ' Zweizimmerwohnungen, ', DREIZW, ' Dreizimmerwohnungen ', VIERZW, ' Vierzimmerwohnungen und ', FUENFZW, ' Fünfzimmerwohnungen.')); {Gibt aus, wieviele Wohnungen welchen Typs im Haus sind.} END; RUN(zaehlen); 1 Quote Link to comment
