Kapa 0 Posted November 18, 2004 The plant tag displays plant spacing in inches. I would like the spacing to be in feet. How can I make this change. I selected quanity/common name/ spacing under the tag command in the edit plant catalog. Quote Share this post Link to post
Robert Anderson 128 Posted November 19, 2004 I'm going to assume you mean "spread", not "spacing", as spacing is not an option. To get the number in feet, simply change the units of your drawing from "feet and inches" to "feet" using the Units... command. Quote Share this post Link to post
Kapa 0 Posted November 22, 2004 I had the document setup chosen at "feet & inches". But it show 4'-6" as 54 inches. When I changed the units to feet like you suggested, The plant tag rounded the spread to 5 feet. Now, that is not accurate enough for me. I am puzzled. Is this the best the program can do? Quote Share this post Link to post
Robert Anderson 128 Posted November 22, 2004 You have to set the degree of rounding in your Units dialog. The plant should display the spread at the document settings, including the number of digits after the decimal point. Quote Share this post Link to post
Kapa 0 Posted November 23, 2004 I went into Document setup and changed the unit name to feet. Rounding decimal to .005. Rounding base 5. The spread shown for the plant in the object info was 5.5. The plant tag displays the spread at 6. Am I making setup the correct place? Quote Share this post Link to post
Robert Anderson 128 Posted November 24, 2004 Kapa, I went back and looked at the code. The code automatically resets the numbers in the tag to whole numbers (integers) unless the quantity for the plant defintion is set to "area" instead of "count". Try this for your plants. You should be able to see two decimal places of accuracy. Quote Share this post Link to post
Kapa 0 Posted December 7, 2004 Robert, I tried this. It does not affect the spacing units , only the quantitiy of plants on my drawing. Kapa Quote Share this post Link to post
