JackBuilt Posted September 25, 2020 Share Posted September 25, 2020 Forgive me for such an elementary question. Can I insert a Slab and have it slope ie: a garage slab that drains towards the garage opening? On another note can a depression or recess of difference in thickness be made? Say for an elevator pit, or for stepped-down space or garage entrance weather lip. Grazie, thanks, merci Quote Link to comment
E|FA Posted September 25, 2020 Share Posted September 25, 2020 These might help (from VW 2021 help system). The slab drainage tools are not intuitive at all and have some wonky behavior: https://app-help.vectorworks.net/2021/eng/index.htm#t=VW2021_Guide%2FFloors_slabs%2FCreating_slab_drainage_systems.htm I remember seeing an explanation video somewhere out there (YouTube? VW website?) but I don't have a link for that. Adding & subtracting to slabs is a bit easier: https://app-help.vectorworks.net/2021/eng/index.htm#t=VW2021_Guide%2FFloors_slabs%2FEditing_slab_geometry.htm Good luck. Quote Link to comment
rDesign Posted September 26, 2020 Share Posted September 26, 2020 Perhaps this thread and video might be what you’re looking for: 1 Quote Link to comment
JackBuilt Posted September 26, 2020 Author Share Posted September 26, 2020 Hello! Thank you both. @rDesign. That movie is what I was looking for. I've spent quite a while experimenting and not getting there by 2 drains, then deleting them. @Matt Panzer This should be in the app-help (If it's there I didn't find it). Quote Link to comment
E|FA Posted September 26, 2020 Share Posted September 26, 2020 16 hours ago, Inspectorjack said: This should be in the app-help (If it's there I didn't find it). VW staff have lots of "secret" support documents. Here's a wishlist item with a request that management makes it all available: VW University is a start, but with a problematic interface and not all of the content available. 1 Quote Link to comment
JackBuilt Posted September 26, 2020 Author Share Posted September 26, 2020 47 minutes ago, E|FA said: VW staff have lots of "secret" support documents. Here's a wishlist item with a request that management makes it all available: VW University is a start, but with a problematic interface and not all of the content available. Yes. I feel University is a great start and needed, but a mess in many aspects. Progress tracking, version organization and relevance, etc. 1 Quote Link to comment
CipesDesign Posted September 27, 2020 Share Posted September 27, 2020 This may not be entirely relevant to the original question, but.... For my work (one-man shop, mostly custom residential one-offs) I always like to stick with a) what is the simplest way to get there, and b) how does the thing actually get built. So for a typical sloping garage slab I have always found that a Roof Face is by far the easiest and most effective tool in the toolkit. Set slope to 1/4" per foot and set the high point correctly as it relates to the adjacent floor and voila. 4 Quote Link to comment
JackBuilt Posted September 27, 2020 Author Share Posted September 27, 2020 3 hours ago, CipesDesign said: This may not be entirely relevant to the original question, but.... For my work (one-man shop, mostly custom residential one-offs) I always like to stick with a) what is the simplest way to get there, and b) how does the thing actually get built. So for a typical sloping garage slab I have always found that a Roof Face is by far the easiest and most effective tool in the toolkit. Set slope to 1/4" per foot and set the high point correctly as it relates to the adjacent floor and voila. Appreciate your input, very relevant. Although, a convoluted process,, I like the output I got using the actual slab tool with modifiers. Site conditions may cause us to add more grade beams or even supporting piers but I'm OK with noodling that through on site at time of build. I'd prefer they enhance the slab tool for sloping slabs that are not used for roofs with drains. For now, I just changed the, drainage notes to a class that is invisible to get rid of the drain info on my slab that has no drains. 2 Quote Link to comment
rDesign Posted September 27, 2020 Share Posted September 27, 2020 4 hours ago, Inspectorjack said: I'd prefer they enhance the slab tool for sloping slabs that are not used for roofs with drains. I agree 100%. Hardscape objects already can have a slope, whereas Slab objects cannot. Doesn't make much sense to me. 1 Quote Link to comment
Tom W. Posted September 28, 2020 Share Posted September 28, 2020 I find the overlap between Hardscapes + Slabs quite confusing + the fact you can do some things with one + not the other 1 Quote Link to comment
line-weight Posted September 28, 2020 Share Posted September 28, 2020 Is there actually a good reason for slabs and roof faces to be different things? Quote Link to comment
Tom W. Posted September 28, 2020 Share Posted September 28, 2020 Or slabs and hardscapes On 9/11/2020 at 11:00 PM, Tom W. said: Thanks Jeff v helpful. This is all new to me. So the texture on an extrude you can easily rotate using Attribute Mapping tool or in O.I.P. The texture on a hardscape you can also easily rotate both ways but when you do it in O.I.P. the 2D hatch doesn't rotate, only the 3d texture. Incidentally, I found the Attribute Mapping tool worked fine whether in Top/Plan, Top or an Isometric view. Slabs however I can see no way to rotate other than by editing the texture where you can only rotate it by 90 or flip it by 180. What if I have floorboards in a room I want to go diagonally? There must be a way Quote Link to comment
CipesDesign Posted September 28, 2020 Share Posted September 28, 2020 There is only one reason I can think of. One (or all) the tool(s) were deemed inadequate so they decided to create an new one to deal with it. Turns out the new one is also inadequate. It's like if you were to throw a bunch of random herbs in a soup pot, hoping to make it taste better. And it doesn't. So you throw in some more.... etc. Quote Link to comment
line-weight Posted September 28, 2020 Share Posted September 28, 2020 1 hour ago, CipesDesign said: There is only one reason I can think of. One (or all) the tool(s) were deemed inadequate so they decided to create an new one to deal with it. Turns out the new one is also inadequate. It's like if your were to throw a bunch of random herbs in a soup pot, hoping to make it taste better. And it doesn't. So you throw in some more.... etc. Hopefully the analogy doesn't go so far as to mean you can then never un-stir the soup, or we're in trouble. Quote Link to comment
CipesDesign Posted September 28, 2020 Share Posted September 28, 2020 Well in my experience you cannot un-stir it. See this recent thread. It's long and complex but well worth a read... 1 Quote Link to comment
