  • 2
VW2021 - Viewport resizing
patrickbellll
In VW2020 there was a way to resize a viewport and the viewport scaling would change accordingly. This could be achieved through grouping the viewport and the resize the group.
This seems to be broken in vw2021 the viewport is still there but it doesn't show anything anymore.
I did check all the settings again, visibility of classes and layers for that viewport etc. but it does not resolve the issue.
Anyone experiencing the same behavior ?
7 answers to this question
I've messed around resizing Sheet Layer Viewports but found no issue. Can you create a screen recording for this, as there are a number of variables that need to be captured to understand the situation and the problem.
  • If you're on Mac running macOS 10.14 (Mojave) or earlier, open QuickTime Player > File > New Screen Recording
  • If you're on Windows, you'll need to use a third-party app. I use and recommend Captura, but do your own due diligence to decide if you trust it. Get it via the developer's website: https://mathewsachin.github.io/Captura/download/
