JackBuilt Posted September 23, 2020 Share Posted September 23, 2020 Howdy, Is there a repository of sharing style resources? I am looking for a wall style that uses Zip-R or similar sheathing. Thanks Jack Quote Link to comment
Tom W. Posted September 24, 2020 Share Posted September 24, 2020 Erm Jonathan Reeves has some wall/slab/roof styles but I'd just create my own, then you can get exactly what you want. I don't think there are any existing styles in the libraries I'd use off the shelf. More of an issue for me has been finding suitable textures for the materials i'm using. Despite the quantity of resources in the VW libraries a large proportion of it isn't much use. But there's tons of free textures out there so I'd say better to start from scratch + build the exact wall you want. Very quick + easy. Just don't try + change the orientation of a texture on a slab... Quote Link to comment
Guest Wes Gardner Posted September 25, 2020 Share Posted September 25, 2020 @Inspectorjack...if I could find a good high res image of the panel straight on I can make you one in a heartbeat.... Quote Link to comment
Tom W. Posted September 25, 2020 Share Posted September 25, 2020 What is the product? An OSB board with membrane ready-attached to it? Would you make it using two components: one for the OSB (textures of which available for free on several sites) + one for the membrane: mtextur do similar-looking ribbed fabric which could be made the right colour in Edit Image Colour dialog Quote Link to comment
Guest Wes Gardner Posted September 25, 2020 Share Posted September 25, 2020 @Tom W., yes, that's probably the best way...the "green wrapper" could have literally no thickness....if you google Zip-R you'll see what it is... Wes Quote Link to comment
Guest Wes Gardner Posted September 25, 2020 Share Posted September 25, 2020 @Inspectorjack, I think I used 1/2" as the thickness of the actual sheathing...you may want to change its texture to OSB. There's a Saved View in the file that turns the siding off..."Model All" turns it back on. Wes Zip-R House.vwx Quote Link to comment
JackBuilt Posted September 26, 2020 Author Share Posted September 26, 2020 20 hours ago, Wes Gardner said: @Inspectorjack, I think I used 1/2" as the thickness of the actual sheathing...you may want to change its texture to OSB. There's a Saved View in the file that turns the siding off..."Model All" turns it back on. Wes Zip-R House.vwx Howdy Wes and Thank you. I dare say a video instruction series of just developing that model, maybe with little more complexity, could be the basis of a great "Model Set-up" instruction asset. As well as a Design Summit class. Quote Link to comment
