Sam Jones 162 Posted September 18, 2020 Is there any way for VS to obtain the Page Size of a design layer? Of a sheet layer? Quote Share this post Link to post
JBenghiat 333 Posted September 18, 2020 You can use object variables: ovLayerSheetPaperWidth = 167; // double_gs - in inches; layer page/paper width ovLayerSheetPaperHeight = 168; // double_gs - in inches; layer page/paper height Those would be the constants to pass to GetObjectVariableReal Quote Share this post Link to post
Sam Jones 162 Posted September 18, 2020 Thank you ! Works great. Now for ...drum roll... Can you set a design layer's page size? Using "SetObjectVariableReal(TheLayer, ovLayerSheetPaperHeight, LayerHt);" Does not seem to work. Also, setting the page height via the OS seems to set the page for all the design layers. Quote Share this post Link to post
JBenghiat 333 Posted September 18, 2020 I believe set should work, and if not, it's a bug. You may need to reset the layer. Also try get after set to see if the values are sticking. I'm also guessing the values are in mm. Quote Share this post Link to post
Sam Jones 162 Posted September 18, 2020 I'll do some more testing. The "Get" returns values in inches, so it seems strange that the "Set" would use mm, but Ill check. Thanks again. Quote Share this post Link to post
Sam Jones 162 Posted September 18, 2020 BTW, how does one "reset" a layer? Quote Share this post Link to post
JBenghiat 333 Posted September 18, 2020 ResetObject(), just like a drawing object. Quote Share this post Link to post
Sam Jones 162 Posted September 18, 2020 Oh well. "SetObject" does not seem to work. Quote Share this post Link to post
Julian Carr 111 Posted September 18, 2020 This is what I use to get the page dimensions. Note it works on the active layer so you have to store the active layer name, switch to the layer you are querying, then back again on completion. Also note it is returning mm: Procedure GetDrawingSizeRect2(VAR dx1, dy1, dx2, dy2 : REAL; VAR PageWdth, PageHght : INTEGER); VAR s1, s2 : STRING; r1 : REAL; BEGIN IF NOT IsNewCustomObject(gPIOName) THEN BEGIN s2 := GetLName(ActLayer); s1 := GetLName(GetLayer(ghParm)); IF (s1 <> '') & (GetType(GetObject(s1)) = 31) THEN Layer(s1) { switch layers so that GDSR() measures active layer (for use with RIP command } ELSE s1 := ''; END; GetDrawingSizeRect(dx1, dy1, dx2, dy2); r1 := GetLScale(ActLayer); { use this here instead of gLScale because GetDrawingSizeRect() is using the active layer, not the PIO layer } IF s2 <> '' THEN Layer(s2); PageWdth := Abs(dx2 - dx1) / r1 * 25.4 / gUPI; { page width in mm } { use gLScale here so that comparisons are in real world sizes, not scaled } PageHght := Abs(dy2 - dy1) / r1 * 25.4 / gUPI; { page height in mm } END; You can use SetDrawingRect() to set the page size, though you need to consider that the drawing size rectangle represents the printable area for the currently selected printer, not the actual page size. I have a routine that tries to match the drawing size rectangle to the metric or imperial page size. Here's part of it: CONST kPS1m = 148; { ISO Sizes including Super A3 } kPS2m = 210; kPS3m = 297; kPS4m = 420; kPS5m = 594; kPS6m = 841; kPS7m = 1189; kPS8m = 707; kPS9m = 1000; kPS10m = 1414; kPS11m = 330; { 13" Super A3 } kPS12m = 483; { 19" Super A3 } kPS11i = 229; { 9" } { US Arch Sizes } kPS12i = 305; { 12" } kPS13i = 457; { 18" } kPS14i = 610; { 24" } kPS15i = 914; { 36" } kPS16i = 1219; { 48" } kPS17i = 216; { 8.5" } { ASME Sizes } kPS18i = 279; { 11" } kPS19i = 432; { 17" } kPS20i = 559; { 22" } kPS21i = 864; { 34" } kPS22i = 1118; { 44" } CASE gPageFormat OF { if possible, set page size string from found page dimensions } 1: BEGIN { ISO } IF ((PageWdth = kPS2m) & (PageHght = kPS1m)) | ((PageWdth = kPS1m) & (PageHght = kPS2m)) THEN PageSize := 'A5' ELSE IF ((PageWdth = kPS3m) & (PageHght = kPS2m)) | ((PageWdth = kPS2m) & (PageHght = kPS3m)) THEN PageSize := 'A4' ELSE IF ((PageWdth = kPS4m) & (PageHght = kPS3m)) | ((PageWdth = kPS3m) & (PageHght = kPS4m)) THEN PageSize := 'A3' ELSE IF ((PageWdth = kPS5m) & (PageHght = kPS4m)) | ((PageWdth = kPS4m) & (PageHght = kPS5m)) THEN PageSize := 'A2' ELSE IF ((PageWdth = kPS6m) & (PageHght = kPS5m)) | ((PageWdth = kPS5m) & (PageHght = kPS6m)) THEN PageSize := 'A1' ELSE IF ((PageWdth = kPS7m) & (PageHght = kPS6m)) | ((PageWdth = kPS6m) & (PageHght = kPS7m)) THEN PageSize := 'A0' ELSE IF ((PageWdth = kPS9m) & (PageHght = kPS8m)) | ((PageWdth = kPS8m) & (PageHght = kPS9m)) THEN PageSize := 'B1' ELSE IF ((PageWdth = kPS10m) & (PageHght = kPS9m)) | ((PageWdth = kPS9m) & (PageHght = kPS10m)) THEN PageSize := 'B0' ELSE IF ((PageWdth = kPS12m) & (PageHght = kPS11m)) | ((PageWdth = kPS11m) & (PageHght = kPS12m)) THEN PageSize := 'Super A3' ELSE FlagCustom := True; END; 2: BEGIN { US Arch } IF ((PageWdth = kPS12i) & (PageHght = kPS11i)) | ((PageWdth = kPS11i) & (PageHght = kPS12i)) THEN PageSize := 'US Arch A' ELSE IF ((PageWdth = kPS13i) & (PageHght = kPS12i)) | ((PageWdth = kPS12i) & (PageHght = kPS13i)) THEN PageSize := 'US Arch B' ELSE IF ((PageWdth = kPS14i) & (PageHght = kPS13i)) | ((PageWdth = kPS13i) & (PageHght = kPS14i)) THEN PageSize := 'US Arch C' ELSE IF ((PageWdth = kPS15i) & (PageHght = kPS14i)) | ((PageWdth = kPS14i) & (PageHght = kPS15i)) THEN PageSize := 'US Arch D' ELSE IF ((PageWdth = kPS16i) & (PageHght = kPS15i)) | ((PageWdth = kPS15i) & (PageHght = kPS16i)) THEN PageSize := 'US Arch E' ELSE FlagCustom := True; END; 3: BEGIN { ASME } IF ((PageWdth = kPS18i) & (PageHght = kPS17i)) | ((PageWdth = kPS17i) & (PageHght = kPS19i)) THEN PageSize := 'ASME A' ELSE IF ((PageWdth = kPS19i) & (PageHght = kPS18i)) | ((PageWdth = kPS18i) & (PageHght = kPS19i)) THEN PageSize := 'ASME B' ELSE IF ((PageWdth = kPS20i) & (PageHght = kPS19i)) | ((PageWdth = kPS19i) & (PageHght = kPS20i)) THEN PageSize := 'ASME C' ELSE IF ((PageWdth = kPS21i) & (PageHght = kPS20i)) | ((PageWdth = kPS20i) & (PageHght = kPS21i)) THEN PageSize := 'ASME D' ELSE IF ((PageWdth = kPS22i) & (PageHght = kPS21i)) | ((PageWdth = kPS21i) & (PageHght = kPS22i)) THEN PageSize := 'ASME E' ELSE FlagCustom := True; END; END; Quote Share this post Link to post
Sam Jones 162 Posted September 20, 2020 Once you set the variable "PageSize" to appropriate string, are you able to set the page size of the active layer (or any layer for that matter)? I'm under the impression that setting the page size for the drawing is a call to the OS that is not available to VS. Would love to be wrong. I would like to set the page size to be 53mm wide by 18,288mm long using vectorscript. Possible? Quote Share this post Link to post
Julian Carr 111 Posted September 20, 2020 You cannot access the printer settings in Vectorscript. There may also be a physical limit on the page dimensions in the OS. At least that used to be the case. Quote Share this post Link to post
Pat Stanford 1,442 Posted September 20, 2020 I would bet there is a python library that will let you set the printer settings. Quote Share this post Link to post
Sam Jones 162 Posted September 21, 2020 That's wonderful Pat. Just a couple of things. Where do I look and how do I use it in VS? Quote Share this post Link to post
Pat Stanford 1,442 Posted September 21, 2020 It depends on how much you need this functionality Sam. ;-) This python library looks like it MIGHT do what you need. https://wxpython.org/Phoenix/docs/html/printing_framework_overview.html You can run Python inside a VS by using the following VS functions. PythonBeginContext PythonEndContext PythonExecute I have not used any of this, so I may be spitting into the wind. It depends on how much you need this functionality Sam. Quote Share this post Link to post
JBenghiat 333 Posted September 21, 2020 @Sam Jones I assume that you want to set the page area in the drawing — the equivalent of going to File>Page Setup and setting the printable area. This should NOT be a function of the OS print system, as the printer does not necessarily need to match the print area (VW will tile or crop as needed). If you want to actually set a custom page size, the equivalent of pressing Printer Setup… in the Page Setup dialog, then you would need to work with OS settings. Untested, but there is access to set the print area to a single page: const short ovLayerRepaginate = 156; // Public for VS // ovLayerRepaginate (Boolean) // Set() causes the pagination to be recalculated for the given Sheet Layer or Design Layer (useful after manipulating the PrintInfo). // true = set drawing size to one page, false = divide drawing size into multiple pages; // Get() determines how the drawing is currently paginated // true = one page, false = multiple pages Quote Share this post Link to post
Sam Jones 162 Posted September 22, 2020 Everything is going well. I can't set the printer page size, but I can deal with that limitation. Is it possible for VS to get the delta Y of a viewport. It's in the OIP, but I'm not finding a hook. Ever so grateful. Quote Share this post Link to post
Pat Stanford 1,442 Posted September 22, 2020 GetBBox(X1,Y1,X2,Y2); ∆Y=Y2-Y1; ?? Quote Share this post Link to post
Sam Jones 162 Posted September 22, 2020 I think it's Y1-Y2, but I'm just about to check. Quote Share this post Link to post
