Length of a path between two points on a polyline
Özgür
I don't think there is a basic way to do this using Marionette. In Vectorscript there is a Function PointAlongPoly that will give you the distance along the line of each point and then you can just do a subtraction.
You could probably write your own node that would do this in Marionette.
How are you planning to define the two points in your Marionette?
