symo
Issue with duplicating light objects
I like to use multiple light objects for renders, rather than use just spotlight symbols - as I dont need to create focus points (which can get very tedious). For some reason, VW doesnt like me duplicating a light object after I set this with all the required attributes (colour, type, beam angle , etc) - then editing all light objects together in the Visualise palette.
I can successfully duplicate the light object in the design layer:
151117375_ScreenShot2020-09-17at22_54.37(2).thumb.png.e7b3028286858b019683aed6a3bf6f4a.png
but when I try to select multiple light objects in the Visualiser palette and edit an attribute for all - the names of all duplicated light objects disappear and the objects can no longer be edited.
2128381642_ScreenShot2020-09-17at22_54.48(2).thumb.png.cb25500d5462b8f7d5c38203ef80e666.png
1742951650_ScreenShot2020-09-17at22_55.15(2).thumb.png.59383279b203d94b62a74db64cbc52f0.png
Even better, when a viewport is created from the design layer, most of the duplicated light objects inherit some very odd names:
466953444_ScreenShot2020-09-17at22_56.41(2).thumb.png.db4de16473d148c3830408c5cb67fe33.png
After this happens, I can still only edit the original light object - "Light 1" in this case.
It seems to me that this workflow is perfectly logical - would love to know if Im doing something wrong.
Heres the VW file.
Light Render Issue.vwx
Cheers
2 answers to this question
As a work around, could you set the one light the way you want and then use the Eyedropper tool to pick up the attributes and pour them onto the other lights.
I agree that your way should work also.
Cheers Pat - but I couldnt make this work-around work in this case. The only attribute that would copy is the colour. So I would still need to individually set each with pan. tilt and   kind (spot, point, etc). When dealing with several light objects, I need to be able to edit parameters of several objects together. I cant edit multiple light objects in either OIP or visualisation palette in the design Layer.
