MartinBlomberg
Quick search result is gray
Hi,
When I use the quick search (thank you for this feature, love it!) the result comes up grey most of the time, but not all the time.
Why is this? For this example I want to change the lighting options, but it's grayed out, please see image.
thanks!
6 answers to this question
7 hours ago, MartinBlomberg said:
Hi,
thanks!
In the case of "Set Lighting Options" - are you on a Sheet Layer when trying to search for that? In that scenario it's greyed out in the View menu, so it's also greyed out in the Quick Search results.
11 hours ago, MartinBlomberg said:
Hi,
thanks!
Hi Martin,
This is a Windows only issue that we have recently found and we are working on a fix for it.  The problem is a focus issue when you have the document window in focus and you launch quick search with a single key press.  If you use the menu shortcut for quick search instead of the single key press, or you click on the menu bars first you won't see the issue.
As a quick workaround, instead of using the single key press to launch quick search you can use the " Ctrl + , " shortcut that is assigned to the Quick Search menu item under the Tools menu.  You can customize this menu shortcut to whatever you would like in the workspace editor.
Sorry for the problem and we hope to get it fixed soon!
Best Regards,
Ian
10 hours ago, Ian Lane said:
Hi Martin,
Best Regards,
Ian
Thanks Ian for the response.
I'll change the command for now then.
Warm regards, Martin
No, I'm in design layer. It works when I click the menu but not with the quick search.
Obiviously a bug, according to Ian Lane.
Cheer!
I can confirm that this issue will be fixed in 2021 SP1.
Thanks for your help finding the problem!
Thanks Ian, much appreciated! 😃
This topic is now closed to further replies.
