drock019
Creating a 2D poly profile and extruding
I'm trying to figure out how to draw a 2d poly profile and then extrude it.
Once i create the points (using the "real" node and the "point 2d" node) how do i control the order in which the poly is drawn?
I've attached a simple example below.  Shows the points created attached to the "Polygon 2d" node, the desired result and the actual result.
Thanks
Derek
*I know I can create a rectangle using the rectangle node this is just a simple example"
Edited by drock019
@drock019
Unfortunately I don't see the example you meant to attach, but the easiest way to order your points would be to use the List (Ordered) node in the Data Flow category.
Please let me know if you need more guidance!
