Travis.Designer Posted September 12, 2020 Share Posted September 12, 2020 Hi I try run Section Solid Can I remove Section Solid command? Because I intent to change design, add more cube. Thank Travis Quote Link to comment
michaelk Posted September 12, 2020 Share Posted September 12, 2020 If you Ungroup the section solid you will get the original objects back. Quote Link to comment
Pat Stanford Posted September 12, 2020 Share Posted September 12, 2020 @michaelk why are we both on the forum on a lovely Friday evening? If you only need to make minor changes, you can also use the Edit Solids (same shortcut as Edit Group or Edit Symbol) to go back one step and be able to change the source geometry. When you exit the solid it will recalculate based on the changes. Quote Link to comment
Travis.Designer Posted September 12, 2020 Author Share Posted September 12, 2020 (edited) 1 hour ago, Pat Stanford said: @michaelk why are we both on the forum on a lovely Friday evening? If you only need to make minor changes, you can also use the Edit Solids (same shortcut as Edit Group or Edit Symbol) to go back one step and be able to change the source geometry. When you exit the solid it will recalculate based on the changes. Hi @Pat Stanford @michaelk 1/ when use Group object, they will not work with Section Solid. It work with Add Solid. 2/ When I run Edit Solid. Then Edit Solid again to copy other 3 cubes. This is result: They did not cut with new 3 cube. what I should do next? Edited September 12, 2020 by Travis.Designer Quote Link to comment
Kevin McAllister Posted September 12, 2020 Share Posted September 12, 2020 The 3 cubes you added will not cut if its a Solid Addition. I would ungroup twice to get back to where you started and perform a solid section again. Kevin 1 Quote Link to comment
mjm Posted September 12, 2020 Share Posted September 12, 2020 (edited) 5 hours ago, Kevin McAllister said: The 3 cubes you added will not cut if its a Solid Addition. I would ungroup twice to get back to where you started and perform a solid section again. Kevin Hey @Kevin McAllister; first—thanks for the workaround. & also: any info on why the added cubes won't cut? Edited September 12, 2020 by mjm Quote Link to comment
Kevin McAllister Posted September 12, 2020 Share Posted September 12, 2020 (edited) My guess would be that its related to stacking order since that's how the solids commands determine what the cutting object is when there are multiple objects. Maybe select the sectioning surface in the edit mode and choose Send to Front. If you post an example file we may be able to make other suggestions. Kevin Edited September 13, 2020 by Kevin McAllister 1 Quote Link to comment
Travis.Designer Posted September 14, 2020 Author Share Posted September 14, 2020 On 9/12/2020 at 11:02 PM, Kevin McAllister said: The 3 cubes you added will not cut if its a Solid Addition. I would ungroup twice to get back to where you started and perform a solid section again. Kevin Hi Kevin I copy rectange, It did not work Sorry, I could not share file. It' simple cubes and NURBS surface, you could build for testing. Quote Link to comment
Kevin McAllister Posted September 14, 2020 Share Posted September 14, 2020 There are three solutions to your issue. Here's a file demonstrating them both. (A) is a replica of your issue using a Solid Section. (B) is a corrected version where I edited the Solid Section and ran the Add Solids command on the three rectangles. (C) is a corrected version where I edited the extruded rectangle and duplicated the rectangles within the original extrude. (D) is a version where I created the original object using a Solid Subtraction instead of a Solid Section. The Solid Section is being confused by the stacking order after you add your duplicates. I'm not sure if this is a limitation or a bug ( @JuanP do you know?). If I were creating this shape myself I would use a Solid Subtraction. Kevin Solid Subtraction vs Solid Section.vwx 4 Quote Link to comment
Travis.Designer Posted September 18, 2020 Author Share Posted September 18, 2020 On 9/14/2020 at 11:45 PM, Kevin McAllister said: There are three solutions to your issue. Here's a file demonstrating them both. (A) is a replica of your issue using a Solid Section. (B) is a corrected version where I edited the Solid Section and ran the Add Solids command on the three rectangles. (C) is a corrected version where I edited the extruded rectangle and duplicated the rectangles within the original extrude. (D) is a version where I created the original object using a Solid Subtraction instead of a Solid Section. The Solid Section is being confused by the stacking order after you add your duplicates. I'm not sure if this is a limitation or a bug ( @JuanP do you know?). If I were creating this shape myself I would use a Solid Subtraction. Kevin Solid Subtraction vs Solid Section.vwx 176.18 kB · 0 downloads Thank Kevin, I learn a lot from you. 1 Quote Link to comment
