mike-h Posted September 11, 2020 Share Posted September 11, 2020 Hello - anyone got any idea what the problem might be here? I have done the 'Fit walls to objects' - 'Roof' and its clearly struggling to detect the geometry as I see it. I guess I can fudge it by dragging the wall peak down manually but its a very simple form so it would be surprising if that was necessary? Thanks Mike Quote Link to comment
axhake Posted September 11, 2020 Share Posted September 11, 2020 Is it possible to share the file or part of the file so we can have a look? Quote Link to comment
mike-h Posted September 11, 2020 Author Share Posted September 11, 2020 Yep sure - attached. Its just an early massing model of an existing house that I want to add some proposals to (and I'm trying hard to work with a Storey type workflow). I changed the wall style and deleted the wall peaks then ran 'fit to objects' again, and it fitted differently (but still overshot the geometry/ different angle to roof). Changing the wall style back reverted to the form shown in the original post. Weird? 103-Proposed.vwx Quote Link to comment
CipesDesign Posted September 12, 2020 Share Posted September 12, 2020 Is it possible that the Walls and Roof are on the same Design Layer? If so, try separating them and re-run the Fit To command. If not then maybe manual reshape is the expedient option. Quote Link to comment
