Zeno
Hidden lines
Hello.
I need to see the marked lines on screenshot. Using hidden line with lower settings in doesn't appear.
It is a curved baseboard but I'm not able to see the lines.
How can I activate then?
Thanks
Change your Smoothing Angle (Angolo stondamento). 0,10 is a very low value.  I would try 10 and then 70 and see if either of those works better for you.
It sounds like you're trying to see more lines, not reduce them, so in that scenario you'd want to lower the smoothing angle.
However, in your case there aren't actually any edges where you've indicated because your profile has curved edges rather than faceted. There are no "edges" to display because the geometry is all tangential. You'd have to edit your profile in this case to get lines to appear where you've indicated, just like in your first screenshot.
If you need it to be both curved AND show the faceted edges, you'll have to do some clever editing of the profile polyline by adding a tiny jog in the line wherever you want an edge to appear.
I hoped to find a simple solution with Lower hidden line angle.. and I was afraid that this was the only solution...
1 minute ago, Pat Stanford said:
I was just about to post the same as Andy. You only get lines where there are corner points.
so.. in this case where work the hidden line angle exactly, if I need to add vertex on specific points?
The smoothing angle is designed to show edges that are created by corner points and are less than the smoothing angle. Think of a circle being simulated by a polygon. If you create a 36 sided polygon you would have an angle at each vertex of 10°. If you created a 18 sided polygon you would have an angle of 20°. If you set the smoothing angle to 15°, the 18 sided polygon would show as faceted while the 36 sided would not show the edges.
image.thumb.png.36dbef25473270f890a6ab2ed8256d94.pngimage.thumb.png.3d0774edd6b7fe23876074db0d9b6e38.pngimage.thumb.png.d0bbb821fc20fe77ac9d457667c037a8.pngimage.thumb.png.457f1703a1bfa2a9ad5e694def1bde91.pngimage.thumb.png.6a5fb9947b56873a4b7e66965c781ac9.png
Take a look at these simulations of your situation. I took the same polygon, changed some of the vertices to bezier, cubic, and arc and rendered at different smoothing angles. I did not see any difference at angles less than 1°.  Notice that none of the "curve" vertices ever show a line.
  • Like 3
