livespace josha
Retain record format entries when using the "Replace Symbol" command
I have 6 variants of a symbol, with an arrow pointing in different directions. I use these for callouts on electrical support drawings. I attach a record, which populates a worksheet.
Issue example:
- I start with the "arrow up" symbol, and enter in all the data.
- due to some layout issue, I need to swap it to the "arrow down" symbol.
- I use the "replace symbol" command in the OIP
    - when I do that, all my record entries get reset to the default values. So I need to re-enter the values
Is there some way to keep my record entry values when I replace the symbol? Maybe thinking there is something like the Attribute Mapping tool to do this?
Have you tried the replace with symbol command in the modify menu. This has a Record option that may do the trick.
@markddThat's it, thanks! Never thought of using the replace symbol command on a symbol.
The only odd thing is that I lose my symbol scaling (that's a minor issue and a quick fix)
Edited by livespace josha
