Sebasrougs Posted September 2, 2020 Share Posted September 2, 2020 I have a problem,i have used some DomC´s nodes to install some python packages,The numpy and Pillow modules install perfectly but the "scipy" module does not install correctly, I get an error that a 3.6 python version is required.I actually have the 3.5 version that comes with Vw 2020 How can i solve this problem? do i need to install a newer version of Python? Thanks. Quote Link to comment
tbexon Posted September 5, 2020 Share Posted September 5, 2020 Have a look at this thread, i'm not sure how much experience with python you have, but basically VW comes with Python 3.5 packaged within the VW environment, you ~could~ download python 3.6 and manually replace it within the VW installation, HOWEVER I wouldn't recommend this, as you have no way of knowing how that may affect the stability and functionality of Vectorworks itself which, as I understand it, also utilizes said python installation. I believe python may be getting upgraded in an upcoming future release, however @Vlado is the man to answer that. 1 Quote Link to comment
Vectorworks, Inc Employee Vlado Posted September 8, 2020 Vectorworks, Inc Employee Share Posted September 8, 2020 On 9/5/2020 at 5:00 AM, tbexon said: I believe python may be getting upgraded in an upcoming future release, however @Vlado is the man to answer that. Yes, Vectorworks 2021 uses Python version: 3.8.2 2 Quote Link to comment
