JessStu
Where do I find my serial number?
I'm trying to install and set up the newest version of vector works and its asking for the serial number, but I don't know what it is or where to find it
If you are a Service Select member, you can log on and get your serial numbers there from the My Licenses menu item.
If you are not a Service Select member and you truly do not have the serial number you will need to contact VW or your local distributor directly.
The Version (the first part of the serial number) and customer ID (the last part of the serial number) can be seen when you go to About Vectorworks.  That should be enough for VW to help you with the rest.
