Kevin Krautle Posted August 29, 2020 Share Posted August 29, 2020 @ Vectorworks Dev Team I have seen this both in Vectorworks 2019 and 2020 on my mac. In 2020 if i open up a fresh blank document and create two devices, connect them, then copy all of it between the readme design layer and the schematic design, the links look like they follow but the lines never update properly ever again. So if I move the signal block, the lines stay static. This happens about 95% of the time. Once in a blue moon it actually copies properly and the lines update properly when the block is moved. I have seen other times were some circuits work but not all. If I click reroute circuits It looks like the lines are still connected but never update their drawing properly ever again. Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted August 31, 2020 Vectorworks, Inc Employee Share Posted August 31, 2020 Hi Kevin, Confirm that. But I also see that this is fixed in the upcoming new version. Thanks for reporting it. Conrad 1 Quote Link to comment
Matthias Sch. Posted September 13, 2020 Share Posted September 13, 2020 I have the same issue with grouping objects - maybe it fits this topic? Try: - Create 2 Data Term Panels with 16 connectors - Group each panel together - Connect both panel's corresponding ports - Move one of the panels The same happens when grouping is done after connecting. And "ungroup" still does not bring back the updated lines after moving. Matthias Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted September 14, 2020 Vectorworks, Inc Employee Share Posted September 14, 2020 Hi Matthias That doesn't seem to me like the same thing. Not quite sure what you are doing from your description, if you a have moment to record a short movie and send me a sample file that would help. The Connect tool and the Circuit object it creates are designed to locate sockets inside devices at the top level. If you device is inside a group it won't connect (I think). Anyway let me know what you are expecting to be able to do and we'll discuss it. Conrad Quote Link to comment
Matthias Sch. Posted September 15, 2020 Share Posted September 15, 2020 Hi Conrad, since it is not the same thing, I opened a new topic for that: Thanks 🙂 Matthias 2 Quote Link to comment
Kevin Krautle Posted September 29, 2020 Author Share Posted September 29, 2020 I have confirmed this is fixed in VW2021 2 Quote Link to comment
