Foreground Render Sketch Not exporting
mattfox
Hi. I have been trying to export a sheet layer that shows elevations and sections. I am using OpenGL as my background render with Hidden Line as my foreground render. In the foreground render settings I am selecting a careful sketch style. This shows up nicely in Vectorworks. However when I go to export, the foreground lines are no longer visible.
When I export with the hidden line not as a sketch style, the pdf works and shows the hidden line.
I'd love to use the sketch style for a client export, so does anyone have any ideas what might be going on here?
Images attached show the issue.
Many Thanks
Matt
1 answer to this question
Ok. to answer my earlier self... and for others who find themselves stumped by this.
I solved it by going to Advanced properties under the section viewport, then the "Attributes" tab where I changed "Line Style" from "Use Class" to "Use Original". This worked for me.
I hope it helps others faced with this problem.
Matt
