Kengene Posted August 27, 2020 Share Posted August 27, 2020 Hello, Is there a way where I can make a 3d view of a light be different then it's 2d view? For example, on a 3d view of a boom, I would want the lights stacked on top of each other because that's how they would be oriented in real life. However, in a plan view for a light plot, I don't want to stack them on top of each other cause then you can't read their info for the plot. It'd be great if I could edit the two views of the same object independently from one another. I feel like there probably is a way todo this, but I'm having trouble finding out how. Quote Link to comment
markdd Posted August 27, 2020 Share Posted August 27, 2020 (edited) You need to investigate Schematic Views. They are a simple but very clever tool which will get you out of most difficult situations. I'm prepping a Webinar for Vectorworks about them right now for the 23 September if you can wait that long. I will be covering theatrical booms, multi-stacked bridge positions, custom sidelight structures - basically anything that isn't a truss! Edited August 27, 2020 by markdd 2 Quote Link to comment
Kengene Posted August 27, 2020 Author Share Posted August 27, 2020 That sounds great! I will look into Schematic Views on my own for now, but would be very interested in the webinar. Quote Link to comment
capital_Designs Posted August 28, 2020 Share Posted August 28, 2020 @markdd will correct me if I'm wrong... but to help you on your journey, @Kengene : Just remember to draw everything "laid down" (as if it's tipped over on the deck) first! This will ultimately allow the Schematic Views to work properly. I have found myself trapped a few times if I don't really stick to this method. Draw "flat", then tip! 1 Quote Link to comment
