Ed Wachter
Extrude Orientation & Editing Question
Posted (edited)
Attached images show an extrude (highlighted on Image #1) and the editing space of the extrude (Image #2). You'll see that the extruded geometry appears rotated 90 degrees when editing. How can I create these extrudes to avoid this rotation when editing? Is this related to the orientation of the working plane? Or is it normal to need to re-orient when editing?
Any assistance would be greatly appreciated.
Thanks
Ed
2134647474_Image2ScreenShot2020-08-25at3_34_56PM.thumb.png.2df6b182596f045f1edfd57c70e1a177.png
Image 1 Screen Shot 2020-08-25 at 3.34.33 PM.pdf Image 2 Screen Shot 2020-08-25 at 3.34.56 PM.pdf
Edited by Ed Wachter
Unfortunately in VW you should never ever rotate or mirror copies
of Extrudes in VW.
You should even not try to move any Extrudes that contain more
than a single 2D Element. (Although these would be quite handy)
I also would like to do my facade panels by Extrudes with multiple
Rectangles inside. Sooner or later VW will run havoc.
Sometimes even when you try to create them from scratch by
auto plane mode in the correct location but copying or arraying
2D Rectangles in Edit Mode later.
That Extrudes behaviour changed over various VW releases but
I think it got even worse over the last years.
I still fight with my large Extrudes, for a whole facade layer in my
multi year projects but I think the safer way would be to use Symbols
instead for any multi-used panel size and just copy/array these around.
Well, that certainly helps. I have often rotated, moved and mirrored these kinds of extrudes. It sounds like even if I avoid these operations I may still experience some unexpected behavior from VW.
