I have never seen this when having a wall with 2 door symbols in it. I'm using the Split Tool to cut the wall into 2 sections, each with a door in it so I can move one wall further into the room. But every time I try to cut the wall in two it moves the symbols in the wall & is doing weird stuff. I've always been able to trim a wall in between symbols & at the ends wit hthe Split Tool or with a line crossing over it & using the Trim tool with no movement of the symbols in the wall.
Anyone else having this happen?
Would it be a setting somewhere I've changed by mistake?
Any suggestions would be appreciated!
Now the only way I can do this correctly is to re-drawl both walls & re-insert the symbols into the same location. CRAZY!
Update - It is good to know others are having same issue with the symbols in walls when splitting the wall. I've been trying everything I know & trying to find a work around. I have done a complete un-install of everything VW & Nemetschek from my computer, even from the registry. Then a new install, after setting everything back to the way I like & trying the split the wall with symbols in it, the same thing happens, it splits the wall but moves all symbols in it. I have now tried this with my wall style & my 2d door symbol & does not work correctly. Then tried with a VW wall style & my 2d door symbol and it does not work correctly. Then with a VW wall style & a VW 2d/3d point plug in object & it worked. It also works with my wall style & VW 2d/3d point plug in object. This sucks because all I am doing is 2d drafting work & the 2d/3d point plug in object is larger in file size which will make the file size larger which leads to problems with the file. All I need are 2d symbols for the doors & windows & do not see any in the Resource pallet. I even tried to make a 2d door symbol from the VW plug in door & it does not work right when splitting the wall.
Attached is a blank document file with my wall style, my 2d door symbol, & a VW plug in 2d/3d door symbol for anybody else to see if they get the same results or can tell me what the difference is between my 2d symbol & the 2d/3d plug in symbol.
Thanks for any suggestions to resolve this or a good work around. Thanks!
VW wall test file.vwx
Edited by DubmanUpdate
