BizGoz
Hinge markers visible through structure
Wondering if anyone has a work around this problem.
I have my hinge markers set to 'exterior' only, but in structures where there are window on both side of the building, I can see the back of the hinge through the glazing in my elevations. Thoughts?
See attached image:
4 answers to this question
How about using a Section Viewport for your Elevations and limiting the depth of the section so you don't include the opposite windows?
Try overriding the class in the viewport (used for the glazing) to have no texture (or a different texture with no transparency).
@Pat Stanford Yes I've done this in the past but I typically don't like using section viewports for elevations. I like having the freedom to move the markers without it affecting the viewports. Also depending on the design of the building I might need the information beyond the cut. Thank you for the suggestion though!
