Landscape designer
Todd
@rDesign is correct that you can import and export and get the data moved between the different file formats, but I am reading between the lines of your post and it appears you are interested in a workflow where you use both VW and Sketchup on the same project.
My advice is don't even try. While you can get the geometry go move between the files, the objects don't always translate into "native" objects in the other file. Doors in a Sketchup file will not be converted to a VW Door Plug-in Object. So you will end up using both applications at their most basic level without out most of the features that make them worth using.
If you get a file from Sketchup it is a very reasonable starting point to develop a VW model and drawing set. If you have a final VW model and want to send it to Sketchup so they can do a walkthrough that is reasonable. To export a VW file to SU, have someone use SU to modify the file and then bring it back into VW with the changes is not going to work to your satisfaction.
$0.02
  • Like 4
