Annabel Bridge Posted August 18, 2020 Share Posted August 18, 2020 Hi I've got my plan drawn in vwks but I'd like to have only a small section really crystal with the rest blurred. Does anyone know fi this is possible? Thanks! Quote Link to comment
CipesDesign Posted August 19, 2020 Share Posted August 19, 2020 I have done this by drawing a polygon over the portion I want to blur. I make the polygon solid, but reduce the opacity to ±35% (adjust to taste). Another way you do it is by using two Viewports, one on top of the other. You can then use Sketch rendering (and also the poly mask, above) for the blurry part, and place the "crispy" portion on top, perhaps even increasing the line weight of the front/clear portion. 3 Quote Link to comment
Pat Stanford Posted August 19, 2020 Share Posted August 19, 2020 Peter always has the best ideas for things like this ;-) Thanks for sharing. 1 Quote Link to comment
Vectorworks, Inc Employee Popular Post Matt Panzer Posted August 20, 2020 Vectorworks, Inc Employee Popular Post Share Posted August 20, 2020 You could also try: Copy the viewport Crop the viewport but leave a good amount of space around it. Cut Paste as Bitmap Move in position Use Image Effects with Blur, soft Edges, lightness, etc. ScreenFlow.mp4 8 Quote Link to comment
Annabel Bridge Posted August 31, 2020 Author Share Posted August 31, 2020 Thanks guys really helpful, knew there must be a way! Quote Link to comment
