Tom W. Posted August 18, 2020 Share Posted August 18, 2020 I have a series of adjoining hardscapes: they are all the same style but some are level, some are sloping + some are aligned. They have a brick texture assigned to them + I have allocated a surface hatch to that texture. But when I view the hardscapes in 3D hidden line render mode only the level hardscapes display the surface hatch. Is there a reason why the sloped + aligned hardscapes don't display the surface hatch? I haven't investigated further - I'm just playing around with the settings - it just seemed strange that it should behave in this way + thought I'd ask the question... Thanks 1 Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted August 18, 2020 Vectorworks, Inc Employee Share Posted August 18, 2020 Hi Tom I'm looking into this for you. I suspect it is because the underlying type of geometry changes. If the Hardscape is a Slab, then the geometry is an extrude. When it's Aligned Slab, it becomes a mesh. But I will do some more testing and speak to our engineering team to see if I can get to the bottom of it. 1 Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted August 18, 2020 Vectorworks, Inc Employee Share Posted August 18, 2020 Just to let you know, I'm seeing the same issue and have filed a bug with our engineering team. VB-173558 1 Quote Link to comment
Tom W. Posted August 18, 2020 Author Share Posted August 18, 2020 Thanks v much Tamsin 1 Quote Link to comment
