aa.schump Posted August 14, 2020 Share Posted August 14, 2020 My window and door tags are not appearing correctly in the viewports, but look perfect in the model. (Actually, the swings on the windows are missing too, perhaps unrelated) Any advice would be great! Things attempted so far: Flipping the door/window Changing fill of the tag's class Display planer objects is checked for the viewport Display 2D components is checked for the viewport Quote Link to comment
Guest Wes Gardner Posted August 17, 2020 Share Posted August 17, 2020 @aa.schump, can you post a piece of wall where this is occurring? Are you using a Data Tag or the "old skool" door/window tag? Wes Quote Link to comment
aa.schump Posted August 17, 2020 Author Share Posted August 17, 2020 @Wes Gardner Attached is the wall information. I am using the ID tag from the door/window. Image attached for that one as well. Would the data tag tool be the preferred workflow? Quote Link to comment
Guest Wes Gardner Posted August 17, 2020 Share Posted August 17, 2020 @aa.schump... I'm sorry I wasn't clear...I need an actual wall (or a part where the tag isn't working correctly) and yes, I recommend using the Data Tag in viewports as it will scale properly. Wes Quote Link to comment
aa.schump Posted August 17, 2020 Author Share Posted August 17, 2020 @Wes Gardner Wall attached, with a window inside. Untitled 5.vwx Quote Link to comment
aa.schump Posted August 17, 2020 Author Share Posted August 17, 2020 @Wes Gardner I am all for using the data tag in the viewports, but I'm getting this message. I am sure I have a box check/unchecked somewhere. Quote Link to comment
Guest Wes Gardner Posted August 17, 2020 Share Posted August 17, 2020 @aa.schump Here's a screen shot and a copy of your file - the Window tag (the one embedded in the Window tool) seemed to work - it DOES require you to have "Display Planar Objects" turned on for that particular viewport. I also placed a Data Tag (one that's intended for windows) in the viewport, you'll see that when you open the file, it's the lower one. This was done in Service Pak 4 of 2020. Untitled 5 wg.vwx Quote Link to comment
aa.schump Posted August 18, 2020 Author Share Posted August 18, 2020 @Wes Gardner Thanks Wes! That did the trick. Switching to Data tags fro here on out. Quote Link to comment
