2021 - Teaser Tuesday: Performance Enhancements
JuanP
@Josh Loy Cool! So theoretically if you had a fancy AMD processor with 64 cores and you had a theoretical process that could be parallelised across these cores (not including renderworks as I think that could already use any number of cores) there is nothing in VW stopping this from happening? It sounds great and hopefully results in a big improvement.
3 hours ago, Clint Alderman said:
Looking forward to seeing the recommended hardware specifications for VW2021
Considering that adding cores lowers clock speed and increases thermals, I would still go for the fastest CPU base clock speed. For example, the Ryzen 3960 looks like the best performance (and value) in the table below.
@Josh Loy what are you thoughts? Also, how will the GPU/VGM factor into this?
Edited by Mark Aceto
2 hours ago, Mark Aceto said:
So, without being able to test drive this yet, this really doesn’t sound like true multicore performance in the sense that we’ve all been hoping for (as it was announced 2 years ago in a Teaser Tuesday). This sounds more like a workaround to speed up viewing vs drafting/modeling/rendering (at the expense of file size which could be an issue when project sharing).
Hey @Mark Aceto thanks for the feedback, I not exactly sure where you're going with this but any speedup for drafting/modeling/rendering seems like a win to me.  This system is independent of Project Sharing and will have no impact on its performance.
1 hour ago, Mark Aceto said:
This announcement reminds of last year when instead of moving more processes from the CPU to the GPU (VGM) as was the trend from 2015-2018, the workaround was to draw less detail in the background. Reading between the lines, it sounds like GPU and multicore optimization have plateaued, and we should manage our expectations accordingly.
I wouldn't say anything has plateaued or that there are any lines to read between.  We support a vast set of hardware and must provide support for a broad range of workflows while always providing the best experience.  The more tasks we can multi-thread and multi-task the better.
I spend 80% of my time drafting and modeling (not just opening files and viewing the model). I spend 20% of my time plating (wireframe, hidden line, OpenGL). And I'm on a Mac, so I need the fastest single core base clock speed available.
Awesome and I'm sure most users fall into this same category, the performance gains will absolutely help your large model workflows while working in wireframe and OpenGL.  I would also agree and recommend higher clock speeds over core counts as long as you have at least 6 cores; I'm also on the Mac.
Sounds like VW2021 will make use of more storage and faster broadband (to save and share larger file sizes). That said, I automatically uncheck all caching options to minimize file size, so I'll be passing on this feature.
It will use more storage 10 to 30% that I've seen up to this point, and if that's an issue for your broadband it can be easily disable just like "Viewport cache."  I wouldn't make any choices or pass judgement until you try it and are happily surprised. 🙂
Considering that adding cores lowers clock speed, and potentially increases thermals (if VW is actually using more than 1-3 cores), I would still go for the fastest CPU base clock speed.
Some of this logic isn't quite correct.  As clock speed increases the power demand isn't linear, meaning the same 'n' amount of work can be done on 4 cores at lower clock speeds in the same amount of time and using less power than a high clocked processor.  Base clock speeds are pretty useless as the system will ramp up and down the clock speed depending on demand.  You'd probably be better served looking at the single and multi-core turbo speeds since they're generally the limiting factor and usually not far apart.  If you want to get really into it TDP will generally dictate the performance you'll see since cores can run at different speeds and in the end heat limits it all.  Feel free to direct message me if you want to talk about this more or have any additional questions.
As for you processor choices I wouldn't quite agree with your
Thanks, Josh. After rewatching the videos from 2  years ago, I deleted/edited a lot of my initial responses but thanks for taking the time to reply.
As for clock speed, the Turbo Boost speeds have proven to be little more than marketing BS for us Mac users, so the real world turbo usually splits the difference between the base clock and the turbo boost (until it gets too hot). The other point of reference is when my Mac maxes out with the message "Vectorworks 20XX (Not Responding)" and I look at Activity Monitor, and see 1 thread slammed against the ceiling, and all the other threads not even being used. That's why the CPU-constraint has always been the speed of a single core/thread. I don't care about the other 19 threads that aren't even being used if they're dragging down the performance of the one that is being used. The 2nd screenshot shows the "4.5GHz" turbo boost maxing out at 4.26 which is the fastest I ever saw it spike on that 2017 iMac Pro.
2109274385_ScreenShot2018-09-24at6_32.10PM(2).thumb.png.4fcb4e41d7fee7a06cd1b7c758e17c5b.png1065715544_ScreenShot2018-11-18at8_44.05PM(2).thumb.png.12da9e8618abf0d8357957206962d1d1.png
14 hours ago, Mark Aceto said:
Dug up this gem of a Teaser Q&A from 2 years ago which does an excellent job of explaining how multiple CPU cores "shovel" graphics to the GPU, so this really does sound like evolution of that development:
It would be cool to bring back these Q&A sessions, any plans to @JuanP?
It's a little disappointing to hear that there will be no improvements to hidden line rendering.
I find 3d performance not bad as it is. I can spin around my 3d models pretty smoothly most of the time. Most of my time spent waiting for VW to draw something, is spent waiting for it to draw hidden line viewports.
  • Like 3
I also thought it was cool in this video to see what looks to be the same example file being used to show speed improvements for opening large files (around the 6:50 mark) when demonstrating 2018 as they are now demonstrating 2021:
VW2018: 70 seconds
VW2019: 21.8 seconds
VW2020: not clear from the video, fades out after 10 seconds
VW2021: 3.14 seconds
On paper it looks very good, especially such a dramatic decrease in 3 versions, let's hope it translates well across other real-world examples.
  • Like 2
Hi,
this looks promising. Enhancements are always very welcome!
Biplap mentioned in the last Design Summit 2020 that, for us Macusers
Vectorworks 2021 supports Apple Metal.
See this:
https://www.vectorworks.net/design-summit/virtual-keynote?utm_campaign=blog&utm_medium=planetvectorworks&utm_source=button&utm_content=042320summitkeynote&hsCtaTracking=fef62d7d-b19b-4108-bc45-de2b801c36c7%7C2fa30288-08a8-44a9-aced-94cdd10b05e1
Does the Performance Enhancements only enhances the CPU, or does it also affect the GPU (with Apple Metal)?
… or ist the Apple Metal Enhancement a separate thing?
Greetings from Germany
Toby
